Nov 19, 2021
08:29 AM
Nov 19, 2021
08:29 AM
I currently specify using the commercial/automotive version of this part (AC10), and am trying to evaluate if the military version (EC10) can be used instead.
The datasheet for the commercial/automotive version shows Cycling Endurance of 100,000 Program-Erase Cycles (min), and the military version shows a Cycling Endurance of only 100 Program-Erase Cycles (min).
If I were to use the military version in the commercial temp range (-40 to +85 C), would the endurance of the military part approach the commercial, or is this lower value typical of the military part?
Are there any other differences between the versions that would make the military version not okay to use?
Labels
Specialty Memory
