KW
Datasheet Rev L, In Chapter 7.2.4 it was written :
"The 8th word will continue to be driven until the burst operation is aborted (CE# goes to VIH, a new address is latched in for a new burst operation, or a hardware reset)."
But in Figure 13. it shows that the A/DQ pins turn into unknow after RDY disable.
The two are not consistent so make me confused, could you help update it?
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello KW,
The statement on page 22 is not illustrated in Figure 13.  Figure 13 is trying to illustrate the read timings parameters before “//” as shown in the green rectangle.  RDY is flash output signal indicating if the flash output data is ready for controller to read.  RDY itself does not have impact on data bus.
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
Thank you for contacting Cypress Semiconductor.
Please allow us to investigate this  datasheet.  We will communicate any new information
to you as soon as it becomes available.
Albert
AlbertB_56
Hello KW,
Albert
KW
Hi Albert,
   Thanks for the declaration, but I think the diagram after "//" will be an ambiguous part that confusing with the behaviors in page 22 which expect DB to keep before CE disable.
Thank you,
Keter
AlbertB_56
Hello Keter,
Yes, the Applications Team agrees that this may be ambiguous/confusing, but  rest assured, figure 13 does not coincide in any way with regards to the verbiage on page 22.
Albert
