I need to access to external memory S29GL512S with a STM32H7, I verify that HAL drivers from ST don't work with Infineon memories, because only be prepared to work with AMD, FUJITSU, INTEL, and SHARP. I'm sorry because I don't have soo much experience working with parallel memories.
Anyone work before with STM32 devices and memories from family S29GLxxxS.
What is the best way to solve my problem?
Luis Cristóvão
For chip erase. The chip erase command sequence is initiated by writing two unlock cycles,
followed by a set up command. Two additional unlock write cycles are then followed by the chip erase command, which in turn invokes the Embedded Erase algorithm.
Yuvraj
Thank you for contacting Infineon Technologies.
If your device STM32H7 can supports parallel interface then it should be possible it can access to external memory S29GL512S.
Here is the link to download low level drivers for parallel flash https://www.infineon.com/dgdl/Infineon-Low_Level_Driver_for_NOR_Flash-Software-v01_00-EN.zip?fileId=...
Thanks and Regards,
Yuvraj
I verified by your datasheet page 57 then I read the address 0x0026 I will be receive the value equal 0x0002. I have one example from STM32 working with S29GL128S. My code only don't work because when I try read Command Set I have the value 0xFE0F. Do you have any idea where come from this value?
NOR_WRITE(NOR_ADDR_SHIFT(deviceaddress, uwNORMemoryDataWidth, NOR_CMD_ADDRESS_FIRST_CFI), NOR_CMD_DATA_CFI); // Read 0x0026
hnor->CommandSet = *(__IO uint16_t *) NOR_ADDR_SHIFT(deviceaddress, uwNORMemoryDataWidth, NOR_ADDRESS_COMMAND_SET); //CommandSet =0xFE0F
Luis Cristóvão
You have referred wrong data sheet, following is the correct data sheet which you need to refer https://www.infineon.com/dgdl/Infineon-1_GBIT_(128_MBYTE)_512_MBIT_(64_MBYTE)_256_MBIT_(32_MBYTE)_12...
You need to read more about CFI and its look up table. After that you can check whether you can write or read the data.
Please let us know if you still face any problem.
Thanks and Regards,
Yuvraj
Are you able to read data after referring correct data sheet which I have mentioned in my previous response.
Also what I understood that you are reading from address 0x0026 which comes under CFI. Ideally 0x0002 should come but you are getting 0xFE0F. Correct me if I am getting this wrong.
Thanks and Regards,
Yuvraj
Yes, I read this value. I solve this problem I thinks with this solution:
NOR_WRITE(NOR_ADDR_SHIFT(deviceAddress, 1, NOR_CMD_ADDRESS_FIRST_CFI), NOR_CMD_DATA_CFI);
NOR_WRITE(NOR_ADDR_SHIFT(deviceAddress, 1, NOR_ADDRESS_COMMAND_SET), 0x0002); FORCE value to 0x0002
nor->CommandSet = *(__IO uint16_t *) NOR_ADDR_SHIFT(deviceAddress, uwNORMemoryDataWidth, NOR_ADDRESS_COMMAND_SET); read the address of Command set
But I don't know ,I try to use the low driver for read, write and erase all device. Sometimes I can write, others not. Read the address I can read all. Erase the device never put all values stored to 0xFFFF.
For erase chip I tried use this code:
NOR_WRITE(deviceAddress+0x555, 0xaa);
NOR_WRITE(deviceAddress+0x2aa, 0x55);
NOR_WRITE(deviceAddress+0x555, 0x80);
NOR_WRITE(deviceAddress+0x555, 0x10);
I only can erase all device if I write in all address (one by one) the value 0xFFFF and take around 12 seconds to erase all device.
Luis Cristovão
Yuvraj
