qingqing
01:59 AM
- Email to a Friend
在测试ICC1时,按照手册,f=1MHz,这里的频率是只要地址线有变化即可(比如地址线由0x000000变成0x000001),还是需要所有的地址线都进行翻转呢(比如地址线由0x000000变成0xFFFFFF)?
09:35 PM
- Email to a Friend
Thank you for contacting Infineon Technologies.
can you please confirm are you trying to perform a Back-to-Back READ operation?
Thanks and Regards,
Yuvraj
qingqing
11:37 PM
- Email to a Friend
“背对背读取”是要求需要所有的地址线都进行翻转吗?(比如地址线由0x000000变成0xFFFFFF);另外我们想确认的就是测试条件,按照贵司的手册,测试条件为CE#=VIL,OE#=VIH;f=1MHz,Byte Mode ,这样的测试条件是“背对背读取”吗?
10:28 PM
- Email to a Friend
The specification of 1Mhz is for normal address increment (i.e. Address 0 to 1 to 2)
Thanks and Regards,
Yuvraj
