hello
I am using S29GL064N, unfortunately there's no r/b pin on the chip, so I need -6 verilog model for simulating, but it was missing on the website. I only found -1 model. That's not my need.
where could I get no r/b pin verilog model for S29GL064N?
Parallel NOR
- s29gl064n
RY/BY# is an output signal which can be ignored if you don’t want to use it. The below snippet from datasheet mentions how to check status without RY/BY# pins and you can use that instead. It does not seem that there are other differences in the device features so the same model should work.
Apurva
Apurva
thanks a lot. you are right.
