Jun 07, 2021
12:57 PM
Jun 07, 2021
12:57 PM
I am trying to figure out the sector erase timing. Specifically, there is a note in the timing information that states "In the pre-programming step of the Embedded Erase algorithm, all bits are programmed to 00h before erasure" and that this time is not included in the timing information.... so, how log is the pre-programming cycle of the sector erase algorithm ??
Labels
Memory Nor Flash
07:17 PM
Jun 08, 2021
07:17 PM
The pre-programming cycle of the sector erase algorithm is
Typical - 0.49s + 0.5s = 0.99s
Max - 0.49s + 3.5s = 3.99s
Thank you
Bushra
07:17 PM
Jun 08, 2021
07:17 PM
Thank you
Bushra
Jun 09, 2021
04:47 AM
Jun 09, 2021
04:47 AM
Thank you for the information!
