Would you please let me know if there is a PIN or PCN regarding the addition of the ASO Entry Timing constraint specification to the S29GL-S data sheet?
Thank you and regards,
Memory Nor Flash
Unfortunately there is no PIN or PCN regarding the addition of the ASO Entry Timing constraint specification to the S29GL-S data sheet.
Thank you
Bushra
Thank you for contacting Cypress Technical Support, an Infineon Technologies Company. Currently we are reviewing your issue and will get back to you as soon as we find the resolution.
Bushra
Can you please send full MPN number?
Thank you
Bushra
Thank you
Bushra
MPN is S29GL512S10DHI010.
Thank you and Regards,
