Yukitaka
Hello.
Originally I was using S29AL016J70TFI010, but I am in trouble because I cannot get it due to the recent shortage of semiconductors. So I found S29AL016D70TFI010H as an alternative. What is the difference between the two?
Also, S29AL016D70TFI010H has an H at the end. What does this mean? I couldn't confirm it by looking at the datasheet.
I would appreciate it if you could answer.
thank you
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello Yukitaka-san,
Thank you for contacting Cypress Semiconductor.
There is no difference between the S29AL016D70TFI010 vs S29AL016D70TFI010H, as these FLASH memory devices are identical.
The "H" in the suffix is for Cypress internal tracking purposes only, and the "H" is not part of the Ordering Part Number (OPN), and
should not be included as part of the OPN.
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
Hello Yukitaka-san,
Albert
It was my mistake. I'm sorry.
Correctly, it was the difference between S29AL016J70TFI010 and S29AL016D70TFI010H.
AlbertB_56
Hello Yukitaka-san,
There is no difference between the S29AL016D70TFI010H and the S29AL016J70TFI010
with regards to form, fit , function and operation.
The process technology node for the S29AL016D is 200nM
The process technology node for the S29AL016J is 110nM
Other than the technology node dimension, there is no difference
with regards to Form, Fit, Function and Operation.
Hope this helps...
Albert
The process technology node of the "D" is
