Nor Flash Forum Discussions
algr_4779301
Currently I am using an STM32H7B0 with S26KL512S memory. I have read your documents and your LLD drivers correctly. But I am having trouble writing and reading the Status Register Mode from memory
Memory clock frequency: 60 Mhz
Can you help me to use this flash?
Should it be configured at startup?
Best regard
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Thank you for contacting Cypress Semiconductor.
Please ensure no other embedded operation is occurring when attempting to READ or WRITE to the FLASH.  Any commands sent to the FLASH while another embedded operation is executing will be ignored.
Please provide waveform screenshots when READING from the FLASH.  Please include the signal pins as shown
within the S26KL512S datasheet, page 12, Section 4.2:
URL to S26KL512S datasheet:
   https://www.cypress.com/file/213346/download
Please provide waveform screenshots at your earliest convenience.
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
Albert
thank you for your answers but for the moment the problem comes from the microcontroller.
Thank you for the status update.  I will now lock this thread
Albert
