Hi
About this Nor flash,
I can not found following nor flash(S25HS512TFABHI001)
but I can found "S25HS512TFABHI010"
"S25HS512TFABHI001" a right order name ? or wrong one ?
Memory Nor Flash
- dfs
Hi @guanj
S25HS512TFABHI001 - this seems like a wrong part number. According to the part number, the model number of the device will be '00' (S25HS512TFABHI001). And there is no model number '00' mentioned in the datasheet.
S25HS512TFABHI010 - this is a correct part number.
Hope this answers your question.
Regards.
Hi @guanj
Regards.
