Could we please have the full datasheet (that has mechanical dimensions) and 3D model for S25HS512TDPBHI010? If not, how do I register for Semper Access Program as per the datasheet?
" Register for the Semper Access Program and get access to datasheets, application notes, models, software, and
evaluation kits "
Memory Nor Flash
Hi @lh-f1
The full datasheet of S25HS512T has the detailed package diagram. You can get the full datasheet by registering for SEMPER Early Access Program. You can register yourself by filling the form on this link. Once your request is approved, you will be able to access the datasheet on this link.
Regards.
Hi @lh-f1
Regards.
