Hello All,
For S25HS512T flash chip, Can we use the generic jedec driver (m25p80.c and spi-nor.c) files.
Any changes required for this chip.
I want to raw access the flash chip using mtd_debug commands.
I want to use the 256KB sectors, not 4KB sectors. I need the basic functionalities as Erase, write and read
operations.
-Thanks.
Generic driver does not support S25HS-T at this point. You need to configure the Flash to uniform then use cy-nor driver.
You can refer to: https://www.infineon.com/cms/en/product/promopages/semper-solutions-hub/#linux-u-boot-00001 for more details.
Ronak
Ronak
