hello Everyone,
The footprint for S25HS01GTDPBHM03 component is not available in it's Datasheet. Please Let me know where can i get the footprint of it. Expecting a quick reply.
Thanks in Advance!
Hi @Urmila_123
Can you please clarify whether you are referring to the preliminary datasheet or the full datasheet? If you are referring to the preliminary datasheet, you can get the full datasheet by registering for the SEMPER Early Access Program. If you have not yet registered, follow the steps mentioned in this document - https://www.cypress.com/file/521071/download
The detailed package diagram for BGA package is present in the full datasheet of the device on page 120 and 121. Datasheet link - https://community.cypress.com/t5/Semper-Flash-Access-Program/Datasheet-Semper-Flash-with-Quad-SPI/ta...
We also have a design guide for SEMPER flash which has the land pattern recommendations - https://community.cypress.com/t5/Semper-Flash-Access-Program/AN224153-Design-and-Layout-Guide-for-Se...
Regards.
Hi @Urmila_123
Regards.
When i click on the link of datasheet, i was getting "An invalid set of parameters has been specified in the url." I am also registered to semper flash access program. but still i can't open. what shall i do. please suggest.
Thanks in Advance!
Hi @Urmila_123
A closing parentheses is wrongly getting added to the link. Sorry for the inconvenience caused. Try this link - https://community.cypress.com/t5/Semper-Flash-Access-Program/Datasheet-Semper-Flash-with-Quad-SPI/ta...
Regards.
Thank you.
In S25HS01GTDPBHM03, Do we need any Decoupling Capacitors for VCC. How can i get the application note/ technical note for this flash.
Hi @Urmila_123
You can find the design guide here - https://community.cypress.com/t5/Semper-Flash-Access-Program/AN224153-Design-and-Layout-Guide-for-Se...
The recommended schematic is given on page 3 of the document.
Regards.
