I have 50 pcb-s where I can't read device and manufacture ID
component soldered, ABA analysis carried out, error goes with component
What could be the reason?
Another batch of components works without problems.
#DEFINE READ_ID WD=0x9F RD=MAN_ID RD=DEV_ID CE_HI
#MAN_ID=0x34
#DEV_ID=0x2A
pass
*** No precondition file present ****
**** Manufacturer ID matches ****
Found: 0x34, Expected: 0x34
**** Device ID matches ****
Found: 0x2A, Expected: 0x2A
fail
**** Manufacturer ID ****
Scan path malfunction
**** Device ID Error ****
Found: 0x0, Expected: 0x2A
Can you please check with the customer on below questions:
- Do these problematic devices have the same OPN as the working ones?
- Did the customer test a problematic component on a known good board?
- Can they test with sending 0x9F command at both 1-1-1 mode and 4-4-4 mode?
- What is the clock frequency 0x9F command running at?
- Can they read out the CFR3V register value from both good and problematic devices and send to us?
Thank you
Bushra
Thank you for contacting Cypress Technical Support, an Infineon Technologies Company. A quick question did you register for the Semper Access Program? When registering please include your company, company website URL, your contact business e-mail address (no web-based e-mail), and your target application.
Have a wonderful day
Bushra
Thank you
Bushra
Hello
We are waiting response from you on questions sent previously. Re-sending again.
- Did you test a problematic component on a known good board?
- Can you test with sending 0x9F command at both 1-1-1 mode and 4-4-4 mode?
- Can you read out the CFR3V register value from both good and problematic devices and send to us?
Thank you
Bushra
