If the PPB programming of a specific bit is interrupted for some reason, is it possible to re-program the same bit with the same value without doing an erase first?
Hi Ehab,
Thank you for contacting Cypress Semiconductor.
Like all other program/erase operations, it is NOT recommended to perform the PPB program operation on the same location without erase if a previous program operation was interrupted due to any reason. I would request you to go through the following KBA for more clarity - Recover Flash Devices when Power Failure or Reset Happens During a Program or Erase Operation - KBA2.... Once a program/erase operation gets interrupted on any memory location the data being read back from that location becomes untrustworthy and the memory location should be reprogrammed only after a successful erase.
Apurva
