Nor Flash Forum Discussions
thanc_4239586
I've found a SPI NOR Cypress S25fs512s Verilog Model (https://www.cypress.com/verilog/s25fs512s-verilog ) and I get confuse: Spec says that
   Read only bits are never modified and the related bits in the WRAR command data byte are ignored without setting a program or erase error indication (P_ERR or E_ERR in SR1V). Hence, the value of these bits in the WRAR data byte do not matter.
However in the model, I see that:
SR1_V[7] is SRWD bit, it is a Volatile copy of SRWD_NV and a Read only bit, but in above code, it is always updated with data programed by WRAR command. If there is a mistake here ?
Hello
Attached is the updated verilog model. pw is sse.
Thank you
Bushra
BushraH_91
250 solutions authored First comment on blog 500 replies posted
Hello
Thank you for contacting Cypress Community Support. We have received your inquiry and currently reviewing the case. We will get back to you as soon as we find the resolution.
Have a wonderful day
Bushra
Hello
Thank you
Bushra
