S25FL512SAGBHIC10 RDID value
davidbleakley
First solution authored First reply posted First question asked
Uboot detects the device as S25FS512S, but it is marked as FL512SAIHC1.
The parts purchased was expected to be S25FL512SAGBHIC10.
UBoot sf probe reads and displays the RDID.
=> sf probe 2:0
Called board_spi_cs_gpio: 2 0
SF: Lock ops not supported for 01 flash
Using 64KB sector size
SF: Detected S25FS512S with page size 256 Bytes, erase size 128 KiB, total 64 MiB
Flash manufacturer ID is: 01
SF: config: 00 status: 00 00
Is the RDID read-back value of S25FS512S expected?
Is there a list of expected RDIDs? I would have assumed it should be S25FL512S
BushraH_91
750 replies posted 50 likes received 250 solutions authored
Thank you for contacting Cypress Community Forum, an Infineon Technologies Company. Currently we are reviewing the case and  will communicate any new information to you as soon as it becomes available.
Bushra
What is the DeviceID (RDID) you are reading on the S25FS512S? Where was this S25FL512S purchased from?
Thank you
Bushra
Could please let us know u-boot version you are using?
Thank you
Bushra
We are waiting for your response.  Please provide all the requested information.
Thank you
Bushra
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello David,
You had provided the manufacturer's ID as 01h, which is the correct manufacturers ID for both the S25FS512S, as well as for the S25FL512S .  However, please provide the actual device ID that is currently being read from the S25FL512S (as detailed within the photo you had provided).
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
