S25FL512S REMS
yilu_4674641
hello all
I use S25FL512S with STM32,but  I have a problem with REMS cmd:
when SI output 0x90+0x000000+0x0000, SO can only receve manufacture ID(0x01) correctly and can not receive device ID(0x19);
when SI output 0x90+0x000001+0x0000, SO can only receve device ID(0x19) correctly and can not receive manufacture ID(0x01);
I have used oscilloscope and found that : the wave of SI is correct, the firse byte of SO is correct and the second byte has no wave,as follows:
I want to know where is the reason.
thank you very much!
yilu_4674641
I have resolved the problem.because i take the CS to low during the REMS command.
