Hello.
I'm using the S25FL256S with EFM32GG11 of Silicon Labs.
And I have a sample code for 'MX25L25635F'.
I have tried to set to Quad mode.
But I couldn't set it.
I understand that the 'S25FL256S' has Quad mode register in Configuration Register.
I'm trying to set register as below in EFM32GG11.
qspi->FLASHWRDATALOWER = buffer[0]; // Status Register
qspi->FLASHWRDATAUPPER = buffer[1]; // Configuration Register
It can't update the Configuration Register, but the Status Register can it.
Is it need a command for updating the Configuration Register?
- s25fl
No special command is required to program the configuration register for Cypress S25FL256S.
Required commands are WREN command(06h) and WRR command(01h).
When programming the configuration register with WRR command, enter the setting values of both the status register and the configuration register.
Use the WRR command to program the status register in the first byte and the configuration register in the second byte.
These commands are the same as for MXIC MX25L25635F.
After rising the last CS# of the WRR sequence, are tW(WRR write time) specifications satisfied?
Thanks and regards,
Thanks and regards,
KaKi_1384211
Thanks, response.
I have understood that it is not different both.
I will inspect the driver for the timing of CS#.
Please see our low level driver for SPI flash devices available at: https://www.cypress.com/documentation/software-and-drivers/low-level-driver-spi-flash?source=search&... . You can use it as a reference to implement different flash operations in your application.
Thanks and Regards,
Sudheesh
