we have problem with programing S25FL132K connect to Cyclone 4 FPGA over JTAG. Comment from SW Quartus is:
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cable
s are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connect
ed and configured correctly.
Error (209012): Operation failed
ID check is off. Quartus version 13 allows check ID turn off.
If we change S25FL132K to S25FL164K is no problem programing OK, reading OK. We dont know why. You have encountered this problem?
Thank you for your help
Hello Martin,
Did you try with any other S25FL132K devices. How many FL132K devices have you checked ? Just want to make sure it is not a issue with particular FL132K device.
Krishna.
