S25FL128S VHDL Model Block Statement
lestc_981471
Welcome! First question asked
Hi Guys,
I have downloaded the S25FL128S VHDL model (from http://www.cypress.com/simulation-models​), added to my project in Xilinx Vivado and tried to synthesize but got the following error message:"ERROR: [Synth 8-26] block statement with generics or ports not implemented".
It seems that Vivado can't synthesize the "Main Behavior Block" that has a port and port map inside.
I have searched everywhere but couldn't find much information about the Block statement and what I am doing wrong.
For VitalBuf and VitalWireDelay I got the following message: "WARNING: [Synth 8-312] ignoring unsynthesizable construct: non-synthesizable procedure call". In Vivado it also seems that these are not being found for some reason:
Could you please give some advice on that?
Thanks in advance,
Leonardo.
SudheeshK
250 sign-ins First question asked 750 replies posted
Hi Leonardo,
This model is designed to be used only for simulations. They are not synthesizable.
Thanks and Regards,
Sudheesh
SudheeshK
Hi Leonardo,
Thanks and Regards,
Sudheesh
