Hello all,
I am trying to interface S25FL128P Nor flash with STM32F412 microcontroller. I am using a FATFS stack on top of FREE-RTOS, but i am facing problems in communicating with the flash itself. After f_init() and f_start() when i call the f_initvolume() function it returns a error. Can anyone help me on this? or provide any sample code that i can use?
Thanks in advance.
Hello Nithin,
Please find attached the Low Level Drivers (SLLD) for SPI FLASH memory products,
which also includes the S25FL128P.
Hope this helps...
Thank you and regards,
Albert
Hello nithin.nagaraj_3787411,
Are you actually using Cypress' FLASH File System (FFS), with the S25FL128Pxx?
Please clarify...
Albert
Cypress Semiconductor
I am currently using a FATfs from different vendor
