Do you know where I can find the Tjc (thermal resistance junction to case) and max operating junction temperature for the S25FL128LAGNFB013?
The datasheet only states the Tja (thermal resistance junction to ambient) parameter and the ambient temperature.
Jason
Hello Jason,
The thermal parameters are as follows:
Theta j-a : 32 degrees C/W
Theta j-b : 7.8 degrees C/W
Theta j-c : 12.6 degrees C/W
Max. Oper. Junct. temp : 110.76 degrees C
Hope this helps...
Albert
Hello Jason,
Thank you for contacting Infineon Technology. Since you created same inquiry case on the SFDC please refer to [MyCase#: 00700689] - S25FL128LAGNFB013 thermal parameters for detail information.
Bushra
Hello Jason,
Hope this helps...
Albert
