user_4178566
I want to replace FLASH IC from N25Q128A13ESE40G to S25FL127SABMFV101.
Are there any points to change with Soft ware?
AS_36
100 likes received 500 replies posted 250 solutions authored
S25FL127SABMFV101 has temperature range of (–40°C to + 105°C), where as N25Q128A13ESE40G has temperature range of (–40°C to +85°C). Software wise both will be same, as the command set is compatible.
Though we do not have a drop in replacement for this part, the best alternative that we can suggest is S25FL128LAGMFI011. This part has RESET# instead of HOLD# functionality. You can go through this application note for further help if you choose to migrate to FL-L device - https://www.cypress.com/file/202606/download
- Apurva
AS_36
- Apurva
Thank you a lot.
