Requirement for 16-SOIC package dimensions
NaMo_1534561
Distributor - Macnica (Japan)
100 replies posted 100 sign-ins 50 replies posted
In the S25FL256S data sheet, package dimensions are defined by BSC (Basic Spacing between Center).
Could you inform the min and max values of D, E (or E1)?
This information is used to review the board layout.
MPN S25FL256SAGM **bleep**00
In the data sheet of S29GL-S, it was described as min / typ / max.
(Screen shots are attached)
Naoaki Morimoto
Apurva_S
100 likes received 500 replies posted 250 solutions authored
Hi Naoaki Morimoto san,
The tolerances are -
  • D : +/-0.20mm
  • E : +/-0.33mm
  • E1 : +/-0.10mm
Regards.
Apurva_S
Hi Naoaki san,
Could you please go through the land pattern recommendations mentioned in this layout guide - https://www.cypress.com/file/217366/download and let me know if this will answer your query?
Regards.
NaMo_1534561
I got feedback from customers.
The user has created a parts library with CAD, and it is necessary to register the intersection information (min / max value) of the external dimensions to create it.
Naoaki Morimoto
Apurva_S
  • D : +/-0.20mm
  • E : +/-0.33mm
  • E1 : +/-0.10mm
Regards.
NaMo_1534561
Hello AS_36-san,
Thank you for giving the information.
Naoaki Morimoto
