We are currently using this part (S29GL128P11FFI013) in of our products. According to document 001-11743 (Rev. K) this part is about to go obsolete during 2019. Since we are currently doing a revision upgrade on our product we would like to swap this part out. Does Cypress have a drop in replacement part for S29GL128P11FFI013? Or maybe a similar part with the same package (LAA064) but with larger capacity that we can use.
Br
/Martin
Parallel NOR
Part Number Query
Hello Martin,
There is no drop-in replacement for S29GL128P11FFI013. However, the closest recommended replacement will be S29GL128Sxxxxxxxx.
Please refer to attached Migration from GL-N and GL-P to GL-S Flash application note for more detail information.
Thank you and have a nice day
Bushra
Hello Martin,
Thank you for contacting Cypress Community First Forum. Currently we are reviewing the issue and will get back to you as soon as we find the resolution.
Happy Holidays!
Bushra
Hello Martin,
Bushra
Thanks for the quick reply! I will have a look at the data sheets and compare. What does the life-cycle plan look like for the S29GL128Sxxxxxxxx?
Br
/Martin
Hello Martin,
S29GL128Sxxxxxxxx will be supported till 2022 as per Flash Roadmap.
URL for Cypress Flash Roadmap - http://www.cypress.com/file/206951/download (Slide 9)
Thank you
Bushra
