Due to supply difficulties with GL-S 256Mb products, we are considering substituting GL-S 1Gb products.
Please tell us about the treatment on the board of pins A24 and A25 of the address signal, which were not used in the 256Mb product.
We do not need 1Gb because we will use 256Mb capacity.
Is it OK to connect directly to ground externally?
Is external pull-down necessary? If so, what is the recommended resistance value?
Kumada
Memory Nor Flash
Thank you for contacting Infineon Technologies.
Yes, it is OK to connect directly to ground externally.
And
There is no recommended resistance value.
Thanks and Regards,
Yuvraj
And
Thanks and Regards,
Yuvraj
