Nor Flash
ViC_3886151
New Contributor II
Greetings.
I'm using PSoC 5LP in my project along with S25FL127SABMFI101 SPI flash for logging data.
I have done all the steps necessary to include the library emFile. But I'm still not able to format the flash, create a directory and access it.
Its returning 'Failed'. Please help.
I recently started learning PSoC 5LP. Any help is appreciated.
Thanks and Regards
Vinay
AlbertB_56
Hello Vinay,
Thank you for contacting Cypress Development Community (CDC) Forum.
I will need to escalate your query to the PSOC-5LP Group for further technical expertise
Thank you and regards,
Albert
Cypress Semiconductor
ViC_3886151
New Contributor II
Hello Albert,
Thank you for your reply. I need help with serial NOR flash which for some reason is not supported in emFile library.
emFile comes with two different NOR drivers:
  • Block map NOR driver
  • Sector map NOR driver
I cannot find any of those NOR drivers anywhere. Its not present in emFile library too. Please its urgent & I need your help.
Thanks & Regards
Vinay
