Nor Flash Forum Discussions
andpas_qas
we would need to replace a standard QSPI 256Mbit NOR flash memory, 1.8V, package FBGA 6x8mm, ball array 5x5, with an equivalent Radiation Hardened or Radiation Tolerant memory.
If 256Mbit are not available, we could decrease size by some amount 128Mb or 64Mb maybe.
Any suggestion?
Andrea
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello Andrea,
The CYRS17B512-133UZMB device is 3.3V, 512Mb, (with VI/O) is currently in development
and will be sampling by the end of this year.  This device does have a core VCC of 3.3V,
but also has the Variable I/O (VI/O) feature that supports 1.8V on the I/O's.
The Military Products Expert would like to know :  who is the end customer?
In the interim, I will communicate any new information to you as soon as it becomes available.
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
Hello Andrea,
Thank you for contacting Cypress Semiconductor.
I am currently currently consulting with our Military Products Specialist.
Albert
Hello Andrea,
The CYRS17B512-133UZMB device is 3.3V, 512Mb, and is currently in development
This device does have a core VCC of 3.3V, but also has the Variable I/O (VI/O) feature
Albert
andpas_qas
unfortunately we don't have dual power supply connected on FBGA pads, only 1.8V.
However, I would know if you have other NOR Flash RadHard solutions with VIO=1.8V, even with a different package (ceramic).
On web site I can find FL-S serie, but only for military application, not space, thus not RadHard.
Please let me know.
Andrea
AlbertB_56
Hello Andrea,
Albert
Hello Albert,
please give a feedback about  CY15V116QSN-108BKXI availability.
Andrea
Hello Andrea,
Who is the end customer?  The Military Products expert has been waiting for your response,
since 24MAY, and thus far no response from you or your team.
Albert
Hello Albert,
I didn't understand this question was a blocking point to know technical status of aforementioned F-RAM memory.
Sorry about this, but I'm not authorized to share such information, specially on a public forum. I hope you understand.
If you need some non-technical information we shall go through a direct private contact and I shall ask about this to our administration.
Please give me a way to contact you privately.
Andrea Pastega
Hello Andrea,
Upon signing on onto the Community, click on your "e-mail" icon,
then click on the "write e-mail" icon to formulate your e-mail response.
Ensure that the recipient is to me, "AlbertB_56."
Albert
Hello Albert,
I sent you a private message with the information you required.
Please let me know if it's ok now to proceed with technical/commercial matters.
Andrea
Hello Andrea,
The specific details of your private message was received.
The Military Specialist states that the CY15V116QSN-108BKXI  is 'Not Radiation Hardened' and also 'Not Recommended as Radiation Hardened Device.'
Albert
Hello Albert,
as I wrote earlier, we need to replace a standard NOR Flash 1.8V, package FBGA 6x8mm, ball array 5x5, with another memory with same package and same voltage, also with smaller density, offering some kind of protection over standard flash.
Original NOR flash is  MT25QU256ABA8E12-1SIT, which is reference for pinout and interface.
Searching on the website the only memory I found is the aforementioned  CY15V116QSN-108BKXI, which is a F-RAM, so even if it's not qualified as RadHard, it should offer some resistance to memory content upset, while is not protected from SEU and SEL, which however are temporary effects, so should allow us to reboot the system if memory content is read with errors.
In this sense, even if it's not truly RadHard it always better than bare NOR flash.
Is this assumption correct?
As alternative, you could provide us a list of RadHard memories which could fit our application?
Searching on website "product selector" is not easy to understand which memories are RadHard and which not.
Andrea
Hello Andrea,
Based on your end customer's specific use case, it is certainly a high risk to assume the boot code will not be affected during a SEU or SEL, or exposure to high radiation levels.  As Cypress' Military Products Specialist had already stated, the CY15V116QSN-08BKXI is 'Not Radiation Hardened' and also 'Not Recommended as Radiation Hardened Device.'
However, if your company decides to employ the CY15V116QSN-08BKX in a manner that is outside the datasheet specifications, your company assumes all accountability and responsibility in the event that a catastrophic failure should occur.
For Rad-Hard products, please indicate the memory density, core voltage, package type and CLK frequency that is desired.  It may take some time to assemble a Rad-Hard list for you.
Thank you in advance...
Albert
Hello Albert,
I understand there's some risk.
However please clarify me if there's an advantage using FRAM over standard NOR Flash.
I assumed FRAM was more robust to radiation than standard flash, even if not RadHard qualified. Is this correct?
About the RadHard list, specifications are those I already wrote:
- density: the more you can
- voltage: 1.8V for both core and I/O
package: FBGA 6x8mm, ball array 5x5
- clock: anything grater than 10MHz
- interface: QSPI
About support, there are several technical matters we need to discuss with Cypress Military/Space expert, so our preference is to have a direct contact, via email.
We are spending a lot of time using the forum and acting in third person.
Furthermore, our buyers will have to contact for commercial matters.
Simply using a forum is not the right way to handle this quickly.
Please give us a direct email contact of FAE/sales persons for military/space products.
Andrea
Hello Albert,
sorry for the insistence.
As information about military / space grade components is not readily available on the website, nor is interesting for users developing industrial applications, we understand this forum is not the right place to have a quick support.
We ask for a direct contact email of FAE / sales persons for military / space products.
Please let us know soon!
Andrea
andpas_qas
Hello Albert,
unfortunately we don't have so much time...
We are trying to replace a MT25QU256ABA8E12-1SIT NOR flash memory powered at 1.8V with something offering some resistance to radiation.
Given that a pin compatible solution with same density doesn't exists yet, we thought to employ a 16Mbit F-RAM.
I see Cypress CY15V116QSN-108BKXI should be compatible, maybe also other similar memories could be available.
Could you confirm that these memories do have resistance to radiation (content not altered)?
There's immediate availability for these memories, at least some samples?
Andrea
