yuxi_3250341
First like received
Hi Cypress team,
In S29JL064H datasheet page 33, there's the "Data# Polling Algorithm" flow char, as shown below:
At “DQ5=1?", the "No" arrow leads to the beginning of "DQ7=Data?"
-- Is this accurate? I think here we should let it return to the previous read op, viz. it should lead to the "Read DQ7-DQ0 Addr = VA" square after "START".
My guess is confirmed in S29JL064J datasheet page 35 Figure 8, and S29GL01GT datasheet page 39 Figure 7, whose "Data# Polling Algorithm" are as follows:
Can you confirm which flow chart is correct? The Figure 11.1 in S29JL064H datasheet seems inaccurate, can you confirm this?
Thank you & Best Regards~!
xieyl
March 1, 2020
Apurva_S
100 likes received 500 replies posted 250 solutions authored
Hi xieyl,
Thank you for contacting Cypress Semiconductor.
Yes, your understanding is correct. The correct operation flow should be to read DQ7 - DQ0 again after checking for DQ5 = 1? and then check for DQ7 = Data?
Apurva
Apurva_S
Hi xieyl,
Apurva
Hello Apurva, thanks for your help!
Best Regards
xieyl
March 02, 2020
