1.I'am reading the device id in 1s-1s-1s mode
2.enable 3 byte to 4byte by B7 cmd
4. reading all the registers values (status register 1-00h, status register 2-00h,cfgr register 1-00h,cfgr register 2-88h,cgfr register 3-00h,cfgr register 4- 08h) by 65 cmd with respective addresses(32 bits-1f in hexadecimal ) with read cycle of 8 bits .
5.enable write to volatile registers (cmd 50)
6.write enable cmd 71 with address and data , first iam writing in cfgr 1 -data 02 bit[ 1] should be high to enable 1-4-4 mode
7.write to volatile register 50 cmd
8.write enable cmd 71 with address and data , then iam writing in cfgr 2 -data E8 bit[ 6] and bit [5] should be high to enable 4-4-4 mode, this I'am writing in 1-4-4 format then its is convert to 4-4-4
9. after writing into all the registers i'am reading cfgr 1 ans cfgr 2 the values it showing is for cfgr 1-22 and for cfgr 2-33 that all are wrong values can you tell what is the issue i checked value for status register's also after write immediately it showed the value 02 means write is happening but i'am not getting where the issue is , that registes read and write in diff diff mode i have done that properly and also checked thrice?
see the attached pdf quer 2
can see the memory window and let me know what is the issue ?
Hello Shraddha,
Thank you for contacting Infineon Technologies.
Please verify and confirm the following:
1). After entering the 1-4-4 mode, verify and confirm Device ID is '342A1A0F.' Use RDQID command : AFh
2). After programming Config. Register-2 (CFR2V) to E8h (4-4-4), verify and confirm that STR1V[5] and STR1V[6] are not set to 'ONE' (program/erase error flag). Use RDSR1_0_0 Command : 05h
3). If STR1V[5], STR1V[6] and STR1V[1] = ZERO (no error), verify and confirm value of Config. Register-2 (CFR2V) is actually E8h. Use RDARG_C_0 command : 65h
Please let us know of your findings/results
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
Hello Shraddha,
You had indicated previously that the Latency Cycle is 00. What is the frequency at which the S25HL512T is currently operating, now?
Albert
< CORRECTION >
Hello Shraddha,
< CORRECTION MADE IN #2 - DISREGARD PREVIOUS MESSAGE >
2). After programming Config. Register-2 (CFR2V) to E8h (4-4-4), verify and confirm that STR1V[5] and STR1V[6] are not set to 'ONE' (program/erase error flag). Use RDSR2_0_0 Command : 0h
Albert
< CORRECTION >
Hello Shraddha,
2). After programming Config. Register-2 (CFR2V) to E8h (4-4-4), verify and confirm that STR1V[5] and STR1V[6] are not set to 'ONE' (program/erase error flag). Use RDSR2_0_0 Command : 07h
Albert
Write command itself not happening I checked by configuring other volatile registers say CFGR3 for read latency cycle its reading 00 . Do we need to look into the protection part?
WRENV(50 CMD) will only work with WRENB_0_0 cmd 01 not with WRENB_0_0 cmd 71 confirmation?
Hello Shraddha,
The Write Enable Volatile command (WRENV_0_0 : 50h) works with Write Register command (WRR : 01h)
The Write Enable command (WRENB_0_0 : 06h) works with Write Any Register command (WRAR : 71h)
Albert
