maglof
First question asked Welcome!
We are a small EMS located in Stockholm, Sweden. One of our customers have chosen the Nor Flash circuit S29GL256S11DHIV20 (an FBGA-64 case) for one of their latest projects.
The customer has tasked us with finding out if this circuit can be programmed by us before we mount it on their boards. We have limited experience with pre-programming chips in BGA-casings, though, and are not sure how to proceed with their request.
Is there an suitable hardware adapter for fitting a BGA-capsule (without damaging the balls) adn does there exist a software package for flashing the circuit this way?
BushraH_91
250 solutions authored First comment on blog 500 replies posted
Thank you for contacting Cypress Technical Support, an Infineon Technologies company.
  1. Let me know what programmer  will be used to program S29GL256S11DHIV20?
  2. Identify if the programmer library has S29GL256S11DHIV20 algorithm?
  3. Do you have programming socket (9mm x 9mm (LAE-064) socket adapter)?
Sending you Programmer Vendor list you can contact.
Thank you
Bushra
BushraH_91
Thank you
Bushra
