I have a problem that I can program Status and Configuration Register using 0x01 command at the first time after the flash powered on, but when I try to re-program the Register, the operation fails and Status Register value becomes 0x5F. Then I I power on the flash again, the value Status and Configuration Register becomes all 0.
How many times can this Registers be programmed. I have programmed the Register about 200,000 times, is it because I have exhausted the use times. Or it is because of some other reasons.
Memory Nor Flash
- s25fl-s
Nonvolatile registers have the same cycling (erase and program) endurance as the main flash array which is 100K P/E cycles.
Also, is it highly unrecommended to perform a program operation on the Status/Configuration register upon every power up. Please see this App note - https://www.cypress.com/file/207641/download
Regards.
Regards.
