- Email to a Friend
I have replaced my Winbond flash w25q256jv with S25FL256SAGNFI010. What are the major electrical points I have to take care of while designing the schematic? is there any particular thing I have to consider while making a design or while writing up the code?
In the initial stage, both the flash seems perfect while compared with each other as far as functional working is a concern.
would like to have your say on this at the earliest as we are in the final stage of our product.
Can you please share with us the sample code for this flash having serial spi flash configuration, erase, read and write operation?
Any help will be grateful. Thanks in advance.
Shivam Shah
Memory Nor Flash
- Email to a Friend
Hello Shivam,
Please find attached the "Infineon, Micron, and Winbond High Density 3.0 Volt SPI Flash Core Command Sets" application note.
Albert
Cypress Semiconductor Corp.
An Infineon technologies Company
- Email to a Friend
Hi Shivam,
For writing your code, you can use our low level drivers that will be useful to interface our flash devices with any microcontroller. The link to download our Low level driver is : https://www.infineon.com/cms/en/design-support/software/device-driver-libraries/memories-for-embedde...
Ronak
- Email to a Friend
