May 04, 2022
02:16 PM
May 04, 2022
02:16 PM
Hi, I am trying to use this part. https://www.mouser.com/ProductDetail/Cypress-Spansion/S25FL128SAGBHIZ00?qs=c5Dptoouu06ybJVLxh47uA%3D...
however the part number does not seem valid per the datasheetthe 6x8mm package has 2 versions
FAB024 and FAC024, one footprint is a 5x5 ball array and the other is a 6x8 ball array
I cannot figure out which part this is. The same part number is used on digi-keyso it is not a distributor website error.
May 04, 2022
09:10 PM
May 04, 2022
09:10 PM
For the S25FL128SAGBHIZ00, model "Z0" indicates Enhanced Security Feature, EHPLC, 4 x 6 ball config. BGA footprint package, with uniform 64 kB sectors.
Please find the attachment for the S25FL128SAGBHIZ00 supplemental (Enhanced Security) datasheet
Ronak
May 04, 2022
09:10 PM
May 04, 2022
09:10 PM
May 12, 2022
11:24 AM
May 12, 2022
11:24 AM
Does that mean that RESETn and VIO is not available even if they balls are there?
May 05, 2022
06:05 AM
May 05, 2022
06:05 AM
Thank you very much
May 16, 2022
10:29 AM
May 16, 2022
10:29 AM
So now the addendum does not cover all versions:
https://www.digikey.com/en/products/detail/cypress-semiconductor-corp/S25FL128SAGBHIA00/13439727
What is the "A0" I was going to use L0 but that is not available. Thanks.
