NOR Flash memory layout guidelines-Reg
Aruna
First like given First like received First question asked
Hi Team,
We are using NOR Flash ( S70GL02GS12FHIV20 ) interfaced with IGLOO2 FPGA for our memory storage application.
Kindly provide the layout guidelines to place and route the memory IC.
Yuvraj
250 replies posted 25 likes received 100 solutions authored
Thank you for contacting Infineon Technologies.
You can refer this application note: https://www.infineon.com/dgdl/Infineon-AN216200_Infineon_Non-Burst-Mode_Parallel_NOR_Flash_Memory_La...
Thanks and Regards,
Yuvraj
Yuvraj
Thanks and Regards,
Yuvraj
