We recently migrated, by compulsion, migrated from S25FL164K0XMFI01 to the S25FL064LABMFI010. I was informed that this was a compatible part but our firmware is generating checksum errors with the new part when we read the contents. Are there subtle differences which would prevent the replacement part ( S25FL064L) from maintaining backward compatiblity with the discontinued S25FL164?
Thank you,
Rob
Hello Rob,
Please review the migration application note. If you still have issue then let me know.
http://www.cypress.com/file/327361/download
Thank you
Bushra
More information...
Our read failures appear to only happen during power up. Once the board is powered-up, subsequent soft resets work fine. Currently, the processor is held in reset after power for approx 200ms, then firmware waits another 1000ms before reading FLASH.
Rob
Hello Rob,
Thank you
Bushra
Bushra,
Yes, thank you for the link. We are all set now.
Rob
Hello Rob,
Awesome. Thank you for letting me know.
Have a wonderful day
Bushra
Hello Rob,
We will look into it and get back to you.
Thank you
Bushra
