Nor Flash Forum Discussions
fewa_4357111
5 sign-ins Welcome!
Dear ALL,
     I want to know the parameters of S25FL512SAGMFIR13, as follows:
     shelf life, exposure time after unpacking during production line, baking time and temperature after damp,MSL(Moisture Sensitive Level).
型号
描述
封装
制造商
shelf life
暴露时限(小时)Exposed limited time (hrs)
Baking oven setting/烘炉设定(Tray 125℃, tape and real 40℃)
MSL等级level
备注
温度
烘烤时间
S25FL512SAGMFIR13
IC_NOR_Flash_Serial-SPI_3V/3.3V_512Mb_9ns_16-Pin_SOP_S25FL512SAGMFIR13
SSOP
CYPRESS
Ferris
Make you stronger
AlbertB_56
500 replies posted 50 likes received 250 replies posted
ENGLISH TRANSLATION WITH ANSWER :
Dear ALL,
     baking time and temperature after damp, MSL(Moisture Sensitive Level).
model : R1 = EHPLC, 16-pin SO pkg. with RESET# and Vi/o
description :  IC FLASH, Serial NOR (SPI) 2.7V to 3.6V, 512Mb, 16-pin SO (300-mil)
manufacturer :  Cypress Semiconductor
Package : 16-pin SOIC (300-mil) package.
Shelf life :  One year
Exposure time limit (hours) Exposed limited time (hrs) : 168-HRS OUT-OF-BAG TIME
Baking oven setting/ oven setting (Tray 125°C, tape and real 40°C) :  Oven setting is +125C - Device carrier must withstand high temperature,  such as a metal tube or bakable tray;  Bakable Tray must withstand (+125C) High Temperature;  Temperature setting
for Tape and Reel (Oven Bake) may not be applicable.  Please verify and confirm that Tape and reel material can withstand (+125C)
high temperature.
MSL level :  MSL = 3 for 16-pin SO (300-mil) package (168-hrs out-of-bag time)--
Remarks
temperature :  I = Industrial temp grade = -40C to +85C
Baking time :  Bake time is 3 to 6 hours to remove any moisture prior to packing  /  Baking of the product is required if  (1) the out-of-bag
time from initial exposure to board mounting is exceeded; (2) the out-of-bag product has been stored at an RH of 10% or greater;  or (3)
the humidity indicator card is greater than 10%.
Hope this helps...
Albert
AlbertB_56
Dear ALL,
high temperature.
Remarks
Hope this helps...
Albert
Dear Albert,
     Thank you for providing the requested information.
     I truly appreciate it,your help in resolving the problem.
Ferris
Make you stronger
