Hello.
I found Maximum Junction Temperature of S25FL256SAGMFIR01.
https://community.cypress.com/message/188372#188372
How is Maximum Junction Temperature of S25FL256SAGMFIR01?
Thanks and Best regards.
Glenn.
Serial NOR
Hi Glenn,
The absolute maximum junction temperature value for S25FS512SDSBHB213 is 112.8 °C
Theta JA = 38.8
Theta JB = 10.2
Theta JC = 11.6
Apurva
Hi Glenn,
Thank you for contacting Cypress Semiconductor.
Could you please clarify your query? Do you want to know the maximum junction temperature of S25FS512SDSBHB213 device?
Apurva
Hello Apurva.
Yes, I want to know the maximum junction temperature of the S25FS512SDSBHB213.
Blenn.
Hi Glenn,
Than you for the confirmation.
You can calculate maximum operating junction temperature of our devices using below formula -
Tj = Theta Ja * P + Ta
Tj: Junction temperature
Theta Ja: Junction to ambient thermal resistance (provided in the previous response)
P: Power consumption of the device (VCC (max) * ICC (max)) (You can consider the Icc(max) value from the datasheet depending upon the operation being performed with the device.)
Ta: Ambient temperature
You can go through the following application note for more details - https://www.cypress.com/file/210756/download
The Theta Ja value is 39°C/W
The Psi Jt value is 5°C/W
Please let me know if you have any further queries.
Apurva
Hello Apurva.
I don't mean Operation Junction Temperature.
I want to know break junction Temperature.
Glenn.
Hello Apurva.
And,
Shouldn't the breakdown temperature be higher than the storage temperature?
Maximum allowable junction temperature for the device S25FL256SAGMFIR01 is 135.4°C.
Thank and Best regards.
Glenn.
Hello Apurva.
I found the maximum junction Temperature of Sync SRAM, Async SRAM, NVSRAM and FRAM.
Maximum Junction Temperature and Power Consumption Calculator - KBA204198
But, there isn't the FLASH memroy.
Glenn.
Hello Apurva.
I understood the meaning of the absolute maximum rated junction temperature.
I want to know just the value of the absolute maximum rated junction temperature.
Glenn.
Hi Glenn,
Theta JA = 38.8
Theta JB = 10.2
Theta JC = 11.6
Apurva
