Hi
Would anyone be able to advise whether leads on cypress components are Matt tin over Nickel or over silver... or something else? The online data for S29AL016J70TFI020 (here https://www.cypress.com/part/s29al016j70tfi020 ) only specifies Matte tin, but in order to justify a tin whisker mitigation plan it is important to identify the barrier between the lead and the tin finish. Any pointers that help identify this would be greatly appreciated.
Many thanks
John.
Yes, The lead frame material of S29AL016J70TFI020 is Cu.
Thank you
Bushra
The alloy type of external plating of the Cu lead frame is Sn 100%, and the finish surface is matte.
In general, Cypress will perform whisker tests based on JESD22-A121 / JESD201, and confirm that the results meet the specifications.
https://www.cypress.com/packaging/pb-free-packaging
Thanks and regards,
Thank you
Bushra
