In S25FL256 datasheet, speed option DP is 66 MHz DDR.
Does it mean that this memory only can work in DDR mode?
Can it work in SDR mode?
Many thanks and regards
I do not quite understand your question, as the default setting for the S25FL256S from the factory is 'serial' as detailed directly below, regardless of speed grade:
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
Thank you for contacting Infineon Technologies.
Yes, the S25FL256S can operate in SDR and is the default setting at power up, as well as support Clock mode 0 and Clock mode 1. Please refer to page 4, table 1 within the S25FL256S datasheet.
Albert
Hi Albert, many thanks for your response.
Then I understand that every model of S25FL256 can work in SDR mode.
S25FL256SDP can work in SDR mode, what it makes different from S25FL256SAG? Can S25FL256SDP perform DDR commands and S25FL256SAG can not?
Many thanks
Albert
