Dec 22, 2022
01:25 AM
Dec 22, 2022
01:25 AM
Is it possible to do Progam Flash array using QPI DDR in S25HS01GT memory model?
Because im seeing in the S25HS01GT Data sheet which does not mention any program command for program Flash array using write QPI DDR. Its mentioned command "ED "only for Read QPI DDR .
Kindly provide the information.
Suresh Muthuraj
01:43 AM
Dec 23, 2022
01:43 AM
No, S25HS01GT does not support program operation in QPI DDR mode.
Thanks and Regards,
Sudheesh
