- Email to a Friend
Could you tell us the maximum PCB trace routing length for address lines , Data lines & Control signals?
By referring the 'Infineon-AN216200_Infineon_Non-Burst-Mode_Parallel_NOR_Flash_Memory_Layout_Guide_for_PCBs-ApplicationNotes-v02_00-EN.pdf', it is understand that overall mismatch within group shall be +/- 500mil. What will be the allowable maximum PCB trace length (considering operating in high speed condition)?
- Email to a Friend
We don't have any recommendation of trace length. As it will change according to the PCB design. You can find the best suitable trace length for your use case by simulating the IBIS model of the device. You can download the IBSI model from here.
Ronak
- Email to a Friend
Ronak
