Nor Flash
NaMo_1534561
Contributor II
The memory capacity and die size of the below two model numbers are different.
Is there a difference in EMS performance such as Radiated electromagnetic field test (G-TEM cell) between these two types of ICs?
MPN:
S25FL256SAGMFBG00
S25FL512SAGMFI010
Naoaki Morimoto
BushraH_91
Unfortunately, we dont have the EMS data to compare between FL256S and FL512S.  So we dont know the exact difference.  However, EMC performance is mainly determined by peripheral circuit type or PKG type, so the difference of EMC performance by density is generally smaller than above.
Thank you
Bushra
BushraH_91
Thank you for contacting Cypress Community Forum, an Infineon Technologies. Currently we are reviewing your issues and will get back to you as soon as we find the resolution.
Bushra
BushraH_91
Thank you
Bushra
NaMo_1534561
Contributor II
Hi Bushra-san,
Thank you for your reply.
Your comment is roughly the same as my understanding.
Naoaki Morimoto
