I designed a board with a zynq and S25FL128SAGBHI200 memory for boot.
The memory seems to be recognized sporadically and it is impossible for me to program it. I would like to check signal integrity of the memory bus by simulation tool. For this, I would like to have the ibis model.
Is it possible to get the IBIS simulation model for the reference S25FL128SAGBHI200 .
Thank you for your help.
- nor flash
Thank you for contacting Infineon Technologies.
IBIS model for S25FL128 is available at: https://www.infineon.com/dgdl/Infineon-S25FL128S_IBIS_Rev5-SimulationModels-v01_00-EN.zip?fileId=8ac...
Thanks and Regards,
Yuvraj
Thanks and Regards,
Yuvraj
Hello Yuvraj,
Thank you very much.
Best regards.
