I want the IBIS model and S-parameters model of S28HS01GTGZBHM030. Where is it on the web? Can you provide me it if it is not on the Web?
Tetsuo
I have attached the S-Parameters model for S28HS01GTGZBHM030 please have a look.
Thanks and Regards,
Yuvraj
Thank you for contacting Infineon Technologies.
Could you please tell me if you have registered for the Early Access Program for Semper? If not, I would like to request you to register yourself here - https://go.cypress.com/semper-access-program-ap . All Semper (S28HS01GT) related documents are available here.
You can download IBIS model by following link: https://community.infineon.com/t5/Semper-Flash-Access-Program/IBIS-Model-1Gb-Semper-Flash-with-Quad-...
Please let me know if you have any more queries.
Yuvraj
Yuvraj-san,
Thank you for your comment.
The link you gave me is the S25 IBIS model. Can it be used for S28HS01GTGZBHM030?
Tetsuo
Yuvraj-san,
Thank you for your support again. I understand.
Is there an S-parameters model?
Tetsuo
Sorry for my previous response I provided the wrong link to get the IBIS model, I provided the Ibis model for S25.
Following link is the correct link to download Ibis model of S28HS01GT : https://community.infineon.com/t5/Semper-Flash-Access-Program/S28HS01GT-Octal-Verilog-Model/ta-p/259...
Thanks and Regards,
Yuvraj
Yuvraj-san,
This URL you mentioned is a Verilog model.
There is IBIS of S28 at the following URL. Is this correct?
https://community.infineon.com/t5/Semper-Flash-Access-Program/IBIS-Model-Semper-Flash-with-Octal-Int...
Tetsuo
Yes, You are correct.
Yuvraj
Yuvraj-san,
Thank you for your support.
I have an another question again. Do you have an S-parameters model?
Tetsuo
Thanks and Regards,
Yuvraj
