Nor Flash Forum Discussions
PiGe_3760021
the product spec for the S25FL256L states:  "By using FL-L family devices at the higher clock rates supported, with Quad commands, the instruction read transfer rate can match or exceed traditional parallel interface, asynchronous, NOR Flash memories..."
but it never states that this device is in fact "NOR" based.
so does it operate like a NOR or NAND device, and do I need to worry about bad blocks?
Thanks for any advice/ comments in advance.
AS_36
Thank you for contacting Cypress Community.
S25FL256L is a NOR Flash memory device, and you need not worry about bad blocks while using any NOR Flash.
Thanks and Regards,
Apurva
AS_36
Thanks and Regards,
Apurva
