I have programmed S25HL nor flash devices using WREN followed by 0x01 by sending status register as well as config options to the device. But in S28HS512 data sheet i do not see this command. Can I use same command to program status and config options for the device if so can you please share the timing diagrams. Please also suggest alternative method to program those registers status 1&2 and all 5 config registers
You can use "Write Any Register (WRARG_C_1)" command to update status and configuration registers of S28HS512T.
Please find more details on page 63 of the datasheet, https://www.infineon.com/dgdlac/Infineon-S28HS256T_S28HS512T_S28HS01GT_S28HL256T_S28HL512T_S28HL01GT....
Thanks and Regards,
Sudheesh
Thanks and Regards,
Sudheesh
