havu
First question asked Welcome!
I have a raw dump from S34ML01G200TFI000
I want to recover/mount this raw image file to my PC. (for extracting some files)
I think this raw image file is Spansion FFS format, but I cannot access files correctly.
Is there any software that provides access to the mount function or file system?
Thanks!
AS_36
100 likes received 500 replies posted 250 solutions authored
Thank you for contacting Cypress Semiconductors, An Infineon Technologies Company.
As you may already be aware, Cypress had announced the closing of the Joint Venture Transaction with SK Hynix System IC (SkyHigh Memory), in April 2019. Please contact SkyHigh Memory, as all NAND Datasheets, Applications Notes, Qualification Summaries, as well as the NAND Community Forum and other NAND related collateral have been removed from view on Cypress.com. I would request you to contact technical support team of SkyHigh Memory.
References:
Cypress Press Release, April 2019:
https://www.cypress.com/news/cypress-announces-closing-joint-venture-transaction-sk-hynix-system-ic
Thank you
Apurva
AS_36
References:
Thank you
Apurva
