boralee
First question asked Welcome!
I need to porting spansion FFS with using S70FL01GS.
I have experience with porting it with FL127S, and it worked well with just little configuration change.
but FL01GS has 2 dies so i faced confusing.
Can i get some information of confinguration with FL01GS ?
I hope fast response, Thanks.
Hello Boralee,
Do not post any of your required information on the Community Forum.
Please send your required information privately to the following e-mail address:  ffs@infineon.com.
Thank you in advance...
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello Boralee,
Thank you for contacting Infineon Technologies.
The S70FL01GS has two FL512S dies, which the pin-out requires two separate Chip Select pins (CS#1 and CS#2).
Therefore, your firmware can be configured to access each FL512S die, because of CS#1 and CS#2.
To receive the FLASH File System Software package, please provide the required information, at your earliest convenience, needed for registration:
Company Name :  ???
Company Address/Location :  ???
Your company/business e-mail address :  ???
Contact Phone Number :  ???
OPN of FLASH device used with FFS :  ???
Upon receiving your information, I will personally register you for the Cypress FLASH File System (FFS) software package on your behalf.
“OPN” = “Ordering Part Number”
After successful registration, your Cypress FLASH File System (FFS) software package will be sent to you, via Cypress’ Customer Relationship Management System (CRM).
Thank you in advance…
Albert
Hello Boralee,
Albert
